I received an error message while tried to launch Manageability Terminal
10 points
Posted on - 10/22/2012
I got my new PC with Intel I3-2100T CPU and Intel DQ67SW motherboard. I followed necessary measures to install it as per the guideline manual. However, from the ISDU I tried to launch Manageability Terminal and I received the error message as under. Have you any idea for this Serial-over-LAN? Please help me to get a remedy.
Thanks in advance.
![Serial over LAN Unable to connect to serial-over-lan port](https://www.techyv.com/sites/default/filesx/users/Images/Unable-to-connect-to-serial-over-lan-port.jpeg)
Serial-over-LAN
Unable to connect to serial-over-lan port (IMR_RES_ERROR). Check that the redirection port is enabled and serial-over-lan feature is turned on.
