Could not play movies in WMP after upgrading to Win 7
I recently upgraded and after it completed I was excited to watch some videos, sadly none of them won't play. Im using windows media player. thats good right?
Ok first things first.
What OS did you upgrade to? What movie files are you playing?
Is it .mkv? .mov? .avi? .wmv?
And Windows Media player isn't really the best out there but it should do while you haven't downloaded anything yet.
1. I upgraded to windows 7 from windows XP.
2. I am not sure, how can I check?
What other player would you recommend if windows media player is not the best. Really appreciate you trying to help.
Windows 7 should have supplied you with the codec for the common video files. Anyhow, you can check the file extension by doing the following:
1. Open windows explorer (the folder in your taskbar).
2. Click organize.
3. Select Folder and Search Options.
4. Go to the View tab.
5. Remove the checkmark on the "hide file extensions for known file types". This should now should the file extensions of all files in your machine.
6. Go check what file extension your movies are.
And while you are at it, I am pretty sure this is a codec problem, try downloading a codec pack. A codec pack is a collection of codec used by players to view certain extensions (.mov / .mkv / .wmv etc) once you have downloaded and installed one, try to view your movies again, it should start to play. Try looking for codec here: http://www.free-codecs.com/. Look for the: k-lite codec pack.
The files are .avi. My brother just arrived and he said I should use VLC player. Is that better? I am also currently downloading the codec pack. Should I just install this once it complete?
VLC player is ok, you can try it out if you want. Ah avi files, I'm pretty sure now that once you install the k-lite codec, you'd be good to go.
Installed the codec and all seems to be working! this is so great! I really cannot thank you enough!
