Hi there,
I am a data entery worker for a medium data processing firm. My job requires me to type with pinpoint accuracy. I have a tendency to use the notepad to make assured notes regarding specific files, but sometimes I forget to save the text in the notepad. Is there any plugin that will setup notepad with autosave funcation?
Thank you
I require a notepad with autosave function
HI Marc,
After reading your ouestion I want you to know that there is no plugin which can make your notepad with autosave function but I tell you that the advance version named notepad++ has autosave function so go for that and I hope this will shot out your problem .
Thanks
Kindly visit this website: http://www.softsea.com/article/Free-Windows-Notepad-Replacements.html. You can see what you need perfectly. About your question: Is there any plugin device to set up the auto save function for your notepad? If you don't have any plugin devices you can use to auto save your notepad function, just always save your work so you can't make a mistake.
