I think my laptop has a bad USB port
Posted on - 04/15/2015
When I place my mouse into port 1, it works totally fine. It doesn't work at all in port 2. At first I thought it was the mouse, but then I put a flash drive into ports 1 and 2, and had the same result. Is there anything I can do to see if I can get that port working again? Or is it just done and I would have to get it repaired? Thank you!
