I install a 512 MB ASUS graphic card. But when I play my video songs or any videos that can not play smoothly. I check my player My player is ok. I use Duel core 2GH, 1GB ram and Intel chips motherboard. I setup my windows to solve this problem. But it is not solve. I face this problem only when I play any kind of videos, It don't gives me any kind of message. Why I face this problem? How can I solve it? Please help me.
Ken Mark
10 points
I use a graphic card but videos do not play smoothly
An overtaxed power supply could cause numerous video clip card problems. Sadly, power supply issues can be extremely difficult In order to identify. The simplest way to make certain that the ability provide isn't creating difficulties would be to exchange inside a known-good high-end power. For many folks that isn't a realistic choice. It's also possible to be able to identify an electric offer difficulty through examining whether the voltages will be in range. The easiest way to check voltages is using any system board monitoring utility that was included with your pc or motherboard. These kinds of resources can verify things like the power provide voltages, inner temperature ranges, as well as fan rates. When you have such a utility then check that the particular voltages are usually where these people belong. If you don't have a system board power you'll be able to try out SpeedFan, SensorsView, or even Motherboard Monitor.
Sadly, several motherboards don't determine their own voltages really precisely. To obtain an accurate voltage reading through upon those motherboards demands opening the PC as well as examining the actual voltages with a voltmeter. If you happen to become enough of an electronics dork to own a single then you can receive an accurate reading this way. Or else you can easily resort to with all the motherboard tools. You will find a few primary current beliefs to check on: 3.3 volts, five volts, and twelve volts. In line with the established specification all three of these voltages should be inside of a few percent. However In real life it really is far better when they are nearer than in which. So 3.3 volts needs to be in between 3.2 to 3.4 volts.
Five volts ought to be coming from regarding 4.8 to 5.2 and a dozen volts should be from 11.6 to be able to 12.4. In the event the voltages are usually outside of that variety, it is not proof of an electric offer issue but it's bad. Several movie credit cards tolerate voltages which can be away from a lot better than other folks. With a lot of brand new movie credit cards, the particular 12 volt benefit is actually the one which is probably to be able to cause problems. When the twelve volt worth suddenly falls when you start upwards the 3D images sport, that's a poor signal. However in the end, the only way to know for sure a power is the cause of the problems is actually to achieve the difficulties disappears right after changing in a far better provide.
Alisha1
Hi John Anderson,
it’s all about compatibility issues. Either your VGA card is not happy with the monitor you are using or the motherboard and VGA are fighting with each other. Whatever the case is eventually VGA card is not adjusting with the system. Check the video card specification in details. Match the refresh rate monitor, i.e refresh rate of monitor should be equal or higher than card. Compare power supply rate as well. Also confirm that VGA is properly installed to operating system. To verify go to My Computer properties, click hardware->device manager. Yellow question mark under monitor/ video controller option indicates you need to install driver. Get the driver and enjoy vedios.
Have a nice time
