I usually get this error-prompt box every time I attempt to open a Word file through double clicking on it. Does anyone here know why this is happening or what is causing this?
Error:
Microsoft Word
Microsoft Word has stopped working
Windows is checking for a solution to the problem…
Hello Victor.
This sort of problem is apparently caused by problems in the system registry. Â The fix for this problem is actually rather lengthy so I will post this link from Microsoft Support site:
https://support.microsoft.com/en-us/help/921541/how-to-troubleshoot-problems-that-occur-when-you-start-or-use-word
There is actually an automated fix via Microsoft Fix It but you can also opt to do it manually by deleting the following registry keys.
HKEY_CURRENT_USERSoftwareMicrosoft Office10.0WordData
HKEY_CURRENT_USERSoftwareMicrosoft Office10.0WordOptions
The "10.0" is for Office 2002 only. Â For Office 2003, 2007 and 2010, replace it with "11.0", "12.0" and "14.0" respectively.
However, the fix is very complex so I urge you to use caution and backup the registry prior to following the procedures.
Hope this helps!
