Hello expert, I have to buy a Samsung galaxy S phone. I viewed on the internet that Samsung galaxy 19000 price in India. When buying that phone in Sri Lanka how much it will be cost as in Sri Lankan rupees?
I viewed on the internet that Samsung Galaxy 19000 price in India
Hello! Gerardo, If you want to buy through internet then through various websites it will cost Rs.21,000 around. There are various websites which give you free shipping to Sri Lanka. So, you can easily check those sites which give you the best price for Sri Lanka. I hope you will get your answer,.
In India it costs around 19000 to 21000 Rupees. To know the approximate price in Srilanka, you can try converting the currency and check. Since the rate varies from country to country depending on the import duty and sales tax and other taxes in countries, you can know the exact price only by checking any local electronic shops. From my investigation, it costs around 25000 rupee.
The Samsung Galaxy S I9000 is a discontinued 3G Smartphone operating on 2G and 3G network bands using GSM and HSPA technologies. It was unveiled to the public on March 2010 and released June 2010 measuring 122.4 x 64.2 x 9.9 millimeters and weighing 119 grams. It uses mini-SIM card and has Super AMOLED capacitive touchscreen display with 16M colors at 480 x 800 pixels screen resolution.
It is protected with Corning Gorilla Glass with TouchWiz UI 3. It runs on Android 2.1 Eclair upgradable to Android 2.3 Gingerbread powered by Hummingbird chipset, 1 GHz Cortex-A8 processor, and PowerVR SGX540 GPU. It supports microSD expandable up to 32 GB. It runs on 512 MB RAM with internal storage available in 8 GB and 16 GB capacities.
The primary camera supports 5 megapixels featuring AF and supports 720p video recording at 30 fps. The secondary camera supports VGA video recording. It has 3.5-millimeter jack, Wi-Fi 802.11 b/g/n with DLNA and hotspot support (Android 2.2 Froyo), Bluetooth 3.0 with A2DP and aptX support, GPS with A-GPS support, FM radio with RDS support, and microUSB 2.0. It has built-in accelerometer, proximity, and compass sensors.
The pre-installed web browser supports WAP 2.0/xHTML and HTML with Adobe Flash support. It runs on removable Li-Ion 1500 mAh battery with standby time up to 750 hours on 2G and 576 hours on 3G. Talk time is up to 13 hours 30 minutes on 2G and 6 hours 30 minutes on 3G. It is available in black and white colors.
For the price, prices vary by store so check with a local store near you.
1....
