jayclarke
Posted on - 11/26/2011
How can I visit sites without leaving any traces on my browsing history ? I am not sure if I can ask this question here, but giving a try. I could use the information for general browsing trace clearing also.
I'm using Opera as my choice application. This is a zealous application, for you can search the entire web including human sites without leaving any trails in your browsing history.
You can download it here Opera.
Now when you have installed it , you should see the uncheck bill bar (retributory stitch on that so the agenda bar instrument materialize on the top of your browser) Then, go to line, and then superior new insular tab and that's it.
You may now carry on any activity without getting caught. lol
If you are using the browsers Mozilla called Firefox, you can install the Add-On called Stealther. This add-on allows you to browse websites in the world wide web, without leaving any traces on your computer. When browsing, this add-on disables the disk cache, cookies, browsing history, downloaded files history, recently closed tabs list, saved from information and sending of referrer header.
This should make it all easy for you, to just go to whatever website you'd like to go to, without any fear of others knowing which sites you have been checking out and visiting.
No NEED of ADD-ONS or Software!!
If you're using browser Mozilla Firefox then OPEN the Browser. Press Ctrl + Shift + P this will take you to a new window & your Private Browsing will start. No history or Cookie will be stored.
If your Browser is Google Chrome then OPEN the Browser. Press Ctrl + Shift + N this will take you to a new window & it's called Incognito Window. Hence no HISTORY or COOKIE will be stored
