I have a mobile. It only supports java. I want to view a pdf file on my mobile. Is it possible to read .PDF from a mobile that supports only Java?
If possible, what kind of software or equipment do I need, to access .PDF ?
I want to access PDF file from java supported mobile
YES it is possible to open .pdf file using your phone. I also have a mobile phone that is java supported , i am currently using a software that can open .pdf file extension.
The name of the software is Adobe Reader 8.jar, it is a java program so it is possible for you to install it on your phone, you can simply download the software in this link.
After you download the software in this link install it on your phone by simply
1. Opening the program
2. Then a pop-up will appear that has an instruction, just press ok to install the program
3. After installing the program, download a file that has a .pdf file extension in your phone for you to test if the program really works.
That's it problem solved!
It becomes quite difficult to find a good application for reading pdf and documents on java phones.
I am sharing few applications that enable you to open pdf and doc format files on your java phone
1. Foliant Reader 0.7.03 special edition: An ebook reader for java mobiles and supports txt formats too.
2. S40 Reader: It is capable of processing both pdf and doc formats.
3. Albite Ebook Reader ver2.0.1: In addition to pdf it is able to process Epub, txt, (x)html.
