For managing a small business network I was using network magic pro from last seven days.
However it was a trial version but I found this more suitable to manage small business network or home network.
Moreover,it is user friendly and automatically creates a single screen map of the entire network so that we can view and manage from one computer.
Now my seven day trial period is over so I want to activate network magic pro, how can I?
Hi Steven Tanner,
In order for your software to be activated, you need to go to CISCO store to buy the product, but unfortunately, the software has stopped its reselling on August 31, 2012.
The link tells you that the software has stopped its function and purchase as of august 31, 2012.
You can contact CISCO for more details.
Hi dear,
Thanks for asking the question.
I have a good one answer to you.
Means of this you can active your software to any other computers with your network provision, your computer done this by own. I am giving you link to solve your problem.first you will install in your computer after this you will active this and then give your password then click on ok your magic pro will be activated.here is some other option for you.
If you have the problem with your password when you will install the software this will asked about your password so you can get a new password from here.
I hope you will like it.
You might think that your problem is unsolvable, but the good news is, there is a solution to your problem.
It's as simple as you uninstalling the software and downloading it and reinstalling it again.
The good news is the software is free to download so you will not use not even one of your money to obtain this software.
Follow this link and it will direct you to the site where you will be able to download the software free.
