I want Ajax Popup box for Mac OS
I want to create some sequence of modal dialogues using Javascript technique. Some of friend suggested me to use Ajax Pop-up box.  Can any one help Ajax download popup for Mac OS. In addition to that can one tell if it is helpful as I want to avoid page reloads.
Best Answer by Waall Mike
Answered By 270 points N/A #159516
Hi there Ashley,
Ajax pop up window is a javascript code that you need to include on your script to work, no need to install any programs to make it work. But there are now some tools that can help you make coding easier  like DHTML website. To help you learn more about this you can visit and find yourself more information regarding this tool you can download their free trial and sample codes. Hope this works for you.
Waall Mike
Answered By 0 points N/A #159517
Hi !
I am sure about your requirement.
I am giving the best reference of free downloadable software.
The best Ajax editor is Thunder Site Free Web Editor 3.0
It is a executable file of 198 MB which supports Windows XP,2000,98, Me
It will allow to make more professional web applications within a minute.
You will be able to create WYSIWYG editor.
This application has a web structure manager.
Thanks
Nowell
