Hello experts,
I want to ask about Google mail password aging.
I haven’t access my Google mail account with username and password for almost 7 months, and I was just thinking if my account or password will expire?
Give me some important updates about Google mail features.
I know there are changes that occurred.
Thank you.
I want to ask about Googlemail password aging.
Hi there,
If one doesn’t logged in into Gmail account for long time. Account may be deleted after not logged in for 9 months on a stretch. Gmail account is market as dormant if you do not log in for 6 months. You can still receive mails while which is marked as dormant. 3 months are subsequent to the dormant status (6 months + 3 months = 9 months) the Gmail account may be deleted. Make sure you login once in 9 months to prevent deletion of your mail account.
Yes there have been a lot of changes on Gmail as there are a lot of new features. There is a video chat on Gmail, SMS chat, SMS update to your phone number once an email is sent to your account. Also in June, Gmail introduced 13 experimental features which are already on Gmail. Some of these features include;
Superstars
Quick Links
Email Addict
Snakey
Custom Keyboard Shortcuts
Random Signature
Just Log in to Gmail once in a while and try out all these new features.
In accordance with GMAIL New Program Policies, The account inactivity will result to termination of your account.
I would suggest that you open your GMAIL account regularly so that it will not result to termination.
Here are the Ten reasons why you should use your Gmail account:
Lesser spam messages.
Search easily.
Easy conversation.
Built in chat.
Can be downloaded to your phone for easy access to your account.
Bigger storage capacity.
Free calls in US. and Canada.
Separates priority inbox.
Secured because it uses Https encryption to keep your emails.
And most of all, IT'S FREE.
sania26
Its very simple to hold on your account again if your account has been expired or you are unable to login.
When you start login your account and there is an error occurred that your username and password is invalid, just look behind the password bar, there is an option come "forget your password", click on it and you find one more page.
Fill the requirements and you'll soon get the message in your back office account and can again enable to login your Gmail account.
Hello Brenda Lopez,
It is very easy to login your account again if you are unable to login. First of all, type your username and password correctly and try to login again. If you are not getting your account by typing login details correctly then you can also try by some another way.
just see below the password bar, there is an option I can't access your account. Just click on that option then a new page will be opened. you will see three options that are:-
1. I do not know my password.
2. I do not know my username.
3. I'm having other problems to signing in.
Then you will find out a new page there will be many options like I forgot my password and I think someone else is using my account and so on. Just select one of them according to your choice then you will find out more instructions. you will get your account soon.
