I want to ask some help about chat bar script.
Hello experts,
I want to ask some help about chat bar script. I am confused on my own programming coding system, I am using php and html programming language to fix my website chat bar script. Do you have some fixed code or script for chat bars? May I have it as a reference?
Thank you.
Answered By 5 points N/A #153414
Developing a chat system is a bit complicated process but there are already built chat systems that provide you the facility to embed it to any web site just by adding some simple HTML code. I’m providing you several links for free chat systems that you can use. Register with them then they will provide you a HTML code. Add the HTML code to your web site and run it. Try all the links below they have different features and management options given. You can add chat rooms or a administrative support chat.
http://www.parachat.com/personal/basic/
https://www.websitetoolbox.com/chat_room/index.html?utm_expid=13854134-5
https://www.purechat.com/
