I Want The Best Free Knowledge Base Software To Help My Co-Workers.
Hello all,
I am working as a Senior Software Developer in IT Company. My Fellow Employees feel trouble to crack a particular logic while I know the solution most of the times. So, I am looking for the Best Free Knowledge Base Software to help my Co-Employees with the information that I have.
Answered By 0 points N/A #162253
Hi, it is an ordinary scenario in most of the Companies, where the seniors want to help their juniors by the Knowledge they have. For this purpose, Knowledge Base Software is created.
I would suggest you to use the free Spiceworks Knowledge Base Software. It will help you in sharing your Knowledge with your juniors and after that, they would be capable of tackling those problems on their own.
Using this Software, you can write articles that can help your IT Team. By learning from your piece of writing, they will be able to help themselves as well.
