I want to change background server information
I am searching for the solution. I want to change automatically the background server information of multiple process chains. Is there any software or program available to do so? Can I create a custom program to change or modify the background server information? Tell me all possible ways.
Best Answer by Zac Winnie
Answered By 0 points N/A #181452
Hi!
I think there is no software available to change background server information. But you can create a custom program to change or modify the background server information. It depends on your programming skills and expertise.
Hopefully this information will help you.
Tritt Rochelle
Answered By 0 points N/A #181453
Dear Kurt Pry,
Thanks for your question. If you want to change the background server information of multiple process chains then you can use the above two software:-
VPN Client Software.
FTP Client Software.
Just download and install them and this will fix your problems.
Best regards,
Zac
Answered By 0 points N/A #181454
There's no software which does that automatically. You may need to try other options like: Google desktop.
