Hi Experts,
I want to change the mac webcam skin. I tried to change it using desktop wall papers but failed. There should any other way. Anyone know how to change the mac webcam skin. My current skin is too dark. It affects eye sight. Thanks.
James Yorath
I want to change the Mac webcam skin ?
Hi James,
According to me currently there is no program that will completely change the look of you Mac , there is Shapeshifter program that can change the menu bar of your mac. You can download the program from here:
https://www.eternalstorms.at/utilities/opaquemenubar/
If you want to change the look and feel of your dock then you can download program from here:
http://leoparddocks.com/index.php
Thanks for sharing your problem with us.
Good Luck.
You mentioned that the skin is too dark and hurts your eyes. Maybe you can adjust the screen saturation or settings. I want to suggest software that a friend of mine is currently using with her Mac. The software is called iGlasses. With this software, you can adjust and tweak your cam setting easily. Here are some of the screen shots:
Here is where you can download it, if you are interested:
https://www.macupdate.com/app/mac/16105/iglasses
