hannahwtc
10 points
Posted on - 12/17/2012
Hello Guys,
Good day. I edit the videos, split them into tiny clips and upload into video browsing web sites. I am a promoter of this job and I need to do it every day on daily basis. I use different softwares to perform this job. I handle different video formats.
I want to compare .avi video format and windows media player and compared to other softwares.
Please help me to know the exact difference so that my work can be more precise.
Thanks for the help.
I want to compare .avi video format and Windows Media Player
Hello
To check and compare two video files you need to check their structural integrity. If you want to do that, you can use AVIcodec 1.2. With that program you get all data about your video including quality and structural integrity. So to compare two videos you need check both videos with this program and then compare given results.
You can download it from here: https://www.videohelp.com/software/AVIcodec
Hi Hannahwtc
As I understand your problem.
Comparing the video resolution of two different formats e.g., (AVI and WMP) or with any other formats, doesn’t tell you anything about the quality.
You can see that different encoders will give you a better quality at less bit rate.
You should know the integral score which is composed of the individual quality factors.
They strongly depends on the.
The type of videos you are comparing
Their length
Their viewing audience
Their original frame work
I hope you’ll get easy way from this solution. Good Luck!
Jhonstoon Leen
