I want to convert using script eml msg?
I have been researching on how to convert using script eml msg. Is there any program/script to convert it? We are using Outlook Express emails (.eml) and we would like to convert them to Outlook emails (.msg). Can we do that?
Best Answer by Lynda M Harvey
Answered By 0 points N/A #148347
Hi Centic,
It possible to convert .eml to .msg while using Outlook Express emails there is a software that can convert .eml and .msg to .eml, .msg , .txt , .html or .tnef and you can download it for free but it is necessary to have the outlook software, this is the link : http://www.clubic.com/telecharger-fiche202600-outlook-eml-and-msg-converter.html or you can use another software and this is the link http://www.emltopst.com/fr/description/
Sincerly,
Douglas
Answered By 0 points N/A #148348
Hi Centic,
You can easily convert .eml to .msg file.There are plenty of freeware available to convert .eml to .msg and vice versa.
You can download the software from the below links and install it on your computer.The conversion is done by generating the *.msg file  corresponding to *.eml file.You can select the location where you want to store your *.msg file.
https://deconf.com
http://download.cnet.com/Outlook-EML-and-MSG-Converter/3000-2369_4-10789439.html
Hope this will help you. All the best.
