I want a cool keyboard
I want some ones suggestion for buying a cool keyboard.
I don't have any lists, I want you to suggest one.
It must be suitable for gaming applications.
The price must be below 1500 Indian Rupees.
I want a keyboard which is unique from others and fresh.
Please give me your suggestion and a small review about that.
Best Answer by kaliberan
Answered By 0 points N/A #137106
Upon doing research, I have not seen a cool gaming keyboard below the price you indicated. however,
I have seen several keyboard, not so expensive, but a little bit higher than the price you want.
1. Genius Lexumate T810 = Rs. 1725
Best Features:
a. Wireless
b. It's 3 in 1 device with a combination of keyboard, mouse and remotes control.
c. It's dimensions is 450 x 150 x 34 mm and weighs only 778 g that makes it easy to carry whenever in transit.
d. It has a transparent base that make it sleek look. You can check out more of this feature
2. Logitech Gaming Combo G100 Keyboard (For PC)  = Rs. 1619
a. It's a device that is plug and play, no need for a driver for it To run in your PC, plus the package is a combination of keyboard and mouse.
 You can check out more of it's feature.
Hope this helps.
Answered By -10 points N/A #137105
There is some what of a gap between your low price average keyboard and a cool keyboard specially designed for games.
Keyboards for games would cost some what 2500 – 3000 Indian rupee. But let me suggest a few…
This is a wireless keyboard with a mouse and joystick. It comes with a 3 year warranty and costs about Rs. 1700. Best Keyboard I could find for you but here are some others,
Saitek Eclipse Backlit Keyboard
Its costs about Rs. 3000, its main feature is its adjustable design, which add to the comfort of the gamer.
Microsoft SideWinder X6 Keyboard
This keyboard has macro keys, adjustable backlight and cruise control. The keyboard is fully capable of being used as your standard keyboard as well as gaming keyboard. It costs about Rs 4000.
Ideazon Merc Stealth Illuminated Gaming Keyboard
The Rs 3500 costing keyboard has 34 additional keys for gaming, it has keys for standard games operations such as jump, run sit. The keyboard comes in three colors; red, blue and purple.
Best most ultimate keyboard is
Logitech G19 Programmable Gaming Keyboard with Color Display
This awesome gaming keyboard boasts of programmable buttons and a color LCD display which shows game statistics, game videos, and images. The user can also change the backlight color on the keys for matching the rest of the gaming setup. This multi-key input keyboard is available at about Rs 9000. This is one of the Best Gaming Keyboard.
