I want to create a simple html5 game. Can html5 programming language create a simple online game? I would like to attract all users to visit my website for our company business. If I will create or attach a small game in a specific website it would be more helpful. Can you share some of your personal or any online codes that can probably help me?
Rebecca Green.
Hi Rebecca,
Yes, you can create games using HTML5. There are lot of professional solutions to create a game.
Once option is to use open source engine Box2D. You need to create a new HTML file to start with.
The source code for creating the game is available in https://code.tutsplus.com/tutorials/build-your-first-game-with-html5–net-20786
You can create exiting games by incorporating Java script Canvas. Rendering will be on Canvas, new HTML5 markup object.
There are different libraries available to enhance your game. ImpactJS, Construct2 and LimeJS are few among them. You can try using them once you successfully develop a simple game.
Thanks!
