I want to create wedding disk label templates
I want to create wedding disc label templates.
Which DVD art software is better for creating these templates ?
Hi Dear,
Thanks For sharing your question on this very fast growing information technology website.
You want to create Wedding Disc Label to write a wedding DVD.
You should use NERO BURNING ROM. It is very best software to make Disc Labels. And it is very easy to use.
On the other hand,you can also make CD/DVD Disc template in Corel Draw.
Thanks
Regards
There are many software's on creating labels that you can purchase in the market.
And you can also download some from the internet.
You can try using CorelDraw Graphics Suite X6 to make disk labels. You can design your own labels.
You can download the trial version from the link:
Another one is the Nero LightScribe which is best for creating disk labels.
The labels are laser-etched so you don't need inks or anything similar.
It will burn your labels directly to your CD/DVD. You can get it from the link:
Notifications
