Hi everyone,
I want to design a speaker case drawing. I need some suggestion about the best photo editing software to be use in this kind of task. My current operating system is windows 7 64 bit, I hope there are some cool and easy to use editing software for windows 7.
Thank you and have a nice day.
Hi Virginia,
For speaker case drawing one of the best software is Eminence Designer. Just search in Google and download it’s very easy to use and you can run this software on windows all versions including NT4.
Another software with the name of Box Designer Edition one of the best feature of this software is having many suitable shapes according to your requirement.
Hi Virginia Adams,
You want to design your speaker case in 2D or in 3D?
In 2D, you can use vector graphic software like Corel Draw, Illustrator, Inkscape or raster software like Corel Photo Paint, Photoshop, and GIMP.
In 3D, you can use 3dMax, Google Sketchup.
All these software are have version for windows 7 64-bit. But, if you want something free, I suggest Inkscape, GIMP and Google Sketchup.
Hope this helps
