I want details about Nvidia Quadro 200D
I am looking to buy a new NVIDIA Quadro 200D, so I want some technical details about this graphics card.
I want it slot type, compatible slot, power consumption and its price in Indian rupees.
Hope someone will give me right answer.
Answered By 0 points N/A #136891
There is no Nvidia Quadro 200D. Did you mean Quadro 2000D? If that is the case, here are the details and specifications you want to know about Quadro 2000D.
Quadro 2000D
Nvidia Quadro 2000D is designed for Windows and Linux desktop workstations. It provides professional and best valued 3D graphics to your applications. This card meets the requirements of advanced diagnostic imaging graphics solutions. Its physical dimension is 4.376”x7” (11.1×17.8cm) single slot. The card is set up in an existing PCI Express 2.0×16 slot (bus type). It features 2x Dual-link DVI connectors that drive two ultra-high resolution digital display. The card consumes a maximum of 62W of power.
The manufacturer’s suggested price is approximately $599 USD or Rs32,900 Indian Rupees. You may buy this at Amazon.com at a sale price of $429.00 USD or Rs23,600 Indian Rupees.
