I want to do auto resize data in crystal report
Hello experts,
I am making  a text file in crystal report from a database.  Data coming from the database is in different format and sizes. I want to resize the text and in the same format. Can I do this automatically? I am looking for a solution about auto resize data in crystal report. Is it possible or not? Have anyone done this before? I hope someone will help me out.
Answered By 0 points N/A #175140
Dear user,
Your query is a very common problem faced by people when making crystal report. I have done a research regarding to your query via Google and have found some solution. You can auto resize the format of your objects by right clicking on the selected object, a check box will appear, tick it "can grow" and you can change its size. If this doesn't help you, then, use the code that I have attached to this solution.
Hope this will help you.
Thank you.
