I want to do a wireless internet connection between two buildings, at the moment there is an existing cable connection to the two buildings. But I want to know if two wireless routers with a crossover cable inserted from one port on one router that is connected to the internet modem can be connected to the other router, also if i can get a wireless setup of this kind. Also how do I get this done please explain in simple language that I can understand because I am not so much a geek in this technical things.
I want to do a wireless internet connection between two buildings?
Good day,
Upon reading your problem I strongly suggest that first of all you should get a professional in networking to get a survey in the site.. and you have to define how many computers will be on the network and how far will be the distance of you access points. Well if you have done those things I would suggest that you should have a research about non – licensed outdoor bridges so it will not give you a high cost. And then choose what’s the best for your preferred connection.
Heres an example of an outdoor bridge.
Hope my Answer helps you.. have a nice day <<techyv.com>>
