I want to download all pokemon 1mb.
Hello experts,
I want to download all pokemon 1 Mb. I am a fan of pokemon cartoon character and I want to download all the wallpaper, screensavers collections in just Mb file, is it possible for me to get it extracted until 1 Mb only? For I want to save it in my mobile phone memory storage.
Thank you.
Best Answer by Michelle Karla
Answered By 10 points N/A #181610
First download your desired file and then convert it to gif format for mobile phone so your file is compressed and it will be less then 1mb file. Just you need is to change the format of the file.
Smith Thompson
Answered By 15 points N/A #181609
This is possible. But you will need to convert the images file into GIF or JPG format. Just open each file on Adobe Photoshop or your Paint program and then save it as GIF or JPG. You can also use other software for converting your images or just go to the link below to convert your files online:
https://www.sodapdf.com/jpg-to-pdf/
Answered By 0 points N/A #181611
Hello Kristen James,
Not all the wallpapers and screen savers are 1mb.
There are less than and more than that. Its size are shown also after the images.
I provided you the links of wallpapers of some pokemons with 1MB below.
Hope this helped you!
