Hello Experts,
I want to download the best technical graphics program. Give me some ways to download the best and secure technical graphics program. I hope it also includes animation and other related graphical interfaces that will really make me as a real artist of course I need a user friendly environment.
Thank you.
Hi Curtis Marry there are so many programs on the internet. But some of them are great for graphical interfaces. All the software require you to practice more and more. It also depends on you that how efficiently you use these software. However I would recommend you to best practice on "Adobe Photoshop", "Adobe Illustrator" for graphics and if you want to create some animation you should definitely use "Adobe Flash". I am giving you the links of these software to download
Adobe Photoshop CS6
Adobe Illustrator CS6
Adobe Flash CS6
Hi Curtis Marry,
There are many graphic programs. Each program has its own advantages and disadvantages. Some program can work with some graphic format, while other work with other graphic format. If you want to become a real artist, you need to learn how to use many programs at the same time.
My suggestion is Adobe Creative Suite. This is a group of software from Adobe Company, include:
Adobe Photoshop: edit, retouch photo
Adobe Illustrator: create vector base graphic
Adobe Flash: create animation
And many other programs
You can download them from http://www.adobe.com/
Hope this helps
