I want to download chrome dom tree Plugin.
I am using a Google chrome browser, and I want to make some improvement with my browser.
I want to download chrome dom tree plugin, how to download and install it in my computer.
Is it compatible with my current operating system which is windows XP?
Best Answer by Roth Bridgette
Answered By 30 points N/A #130592
Hello.
You can download DOM plug-in from the chrome official website.
It is very easy to install and add it to the chrome browser.
Click on the link to download DOM plug-in.
After going to the website click on add to browser to install DOM plug-in.
Thank you.
Answered By 10 points N/A #130593
Dear James,
Every browser uses its own Document Object Model (DOM) or known as Layout Engines.
Google Chrome uses Webkit for representing and interacting with objects in HTML, XHTML AND XML documents.
Here is the link to download the WetKit.Net which is a control library for WebKit written in C# – .
1. Click on the download option,
2. Wait for few seconds to download the program.
I hope it works for you.
Answered By 0 points N/A #130594
You can install the Dom Tree plugin for your Windows XP operating computer. Please make sure you are using the service pack 2 or 3 of the Windows XP on your computer.
Before you install any updates on your computer, I suggest you to perform a system restore to be on the safer side. To install the plugin, you can visit the official website of Google chrome and you’ll have the option to download it.
Just in case if you are unable to download it, please visit the alternative site:
Thanks and regards,
Skarbos Jay.
Answered By 10 points N/A #130595
Hi James A Watkins,
This is how to download and install Google chrome
First download the Google chrome
First Click the Free download then
Second image successful download
Third image right click or double click  the download software then select the open
Then the fourth image click the save file.
Fifth image is preparing for the next installing.
Sixth image click the accept button then
Seven image appear information of Google chrome just click the NEXT
Eight CLICK THE NEXT
Nine image is preparing for the complete download
Ten image is showing for the Google chrome transferring data. so you must wait
After that the Successful download.  This image will tell you that the Chrome is set up everything. Once the Google chrome is successfully download that message will appear telling you that you can directly search then click the change so that your default search engine will change then CLICK MODIFY
Here is the link where you can get free download Google chrome
Hopefully the steps I have shared helps you much.
Answered By 0 points N/A #130596
Thanks to all my friends for helping me.
Roth Bridgette, your step by step system is very easy, and the screenshots are very helpful.
Thanks to your solution, now I am able to download and install it in my computer.
Your free download link is really excellent.
Thanks again Roth Bridgette for your valuable advice.
