I want to download driver USB instant VCD Windows 7. I did a download before but it seems like not working because of some compatibility reasons. I need a software that is compatible with my Windows 7 64 bit operating system, dual core and 2 GHz processor speed.
Thank you.
I want to download driver USB instant vcd Windows 7
Hello Deborah,
You might need a portable installation free video playing software for your PC. If I am getting it right then, here is the solution for you. You can try the portable version of VLC media player or M Player available for free download. Both are good media players and are very famous for their vast file format support.
Both of the downloads are available at https://portableapps.com/
I founded a driver that you need is the ''Usb Instant Vcd Driver Installer''. It is compatible with the Windows 7 with 64 bit, dual Core and 2 GHz processor speed. It is really easy to download it. You can find it at driverscape.com. Its size is normal (file Size 2.14).
