Trevor Jhon
40 points
Posted on - 10/04/2012
Hello experts,
I want to download free Skype ringtone for iPhone. I just got my iPhone and planning to download some cool applications for I am very excited to explore the features of this mobile phone. Can you also give me some website that offers the safest download ever for I don’t want other malicious files may enter the mobile phone system?
Thank you.
Hi Trevor Jhon,
You can go to the link below and click on each link to save the Skype audio.
Download Free Skype Ringtone Here
Save those .m4r files on your PC and then sync it with iTunes to make it work on your iPhone. You will need to use Garageband to make and save ringtones on your iPhone. Sync your iPhone to your computer so you can import the m4r songs. Open iTunes on your PC and from the library, right-click on the Skype ringtone that you just saved and select the Get info option.
Then go to the Options tab and then tick the Start and Stop Time check boxes. Enter the times you want your Skype ringtone to start and stop. The stop time should be 30 seconds. And then click OK. Right-click the song again and choose Create AAC version. The song will be converted by iTunes as a duplicate song. And then right-click on the original song and from the Get info option, bring the start and stop time to the default times. Right-click the short ringtone and then select Show in Windows Explorer. Rename it and then change the extension to .m4r from .m4a. Click Yes and then double-click it to add in your iTunes library. From iTunes, click the Tones from the drop down menu. Your ringtone will be found here. Connect your iPhone and ensure that the Tones is allowed to sync with your iPhone.
When done syncing, tap Settings> Sounds> Ringtone> Select new ringtone.
There are a lot of website where you can get a lot of ringtone for your iPhone or you can go to tool menu and click option to import ring ton. Or you can download ring tone from the link given below.
