Trevor Jhon
40 points
Posted on - 10/17/2012
Hello experts,
I want to download free software for disk speed test version 10. Any instruction or a step by step procedure will do just to obtain a safe and fast download for free on disk speed test version 10. I know you can help me guys regarding this matter.
Thank you.
Hi Trevor,
You can use the Dan Elwells Broadband Speed test software which is available to download at https://dan-elwells-broadband-speed-test.en.softonic.com/. Compared to other software, this tool is compatible to use for Windows which I would assume you're using. It has a user friendly interface and does more than just speed testing. It can trace routes, archive results and export/import files as well.
You may also browse the reviews for other tools listed on this site.
Cheers.
