I want to download ms publisher quiz in PDF form.
I just want to be sure if it is alright to download ms publisher quiz in pdf form even though I am using windows xp operating system? I need your advise about this issue experts. Thanks
There are no compatibility issues when downloading PDF files in different operating systems like Mac, Windows XP or later versions. What you should look at is if you have a PDF viewer. To make sure that you will not have problems with opening the PDF file, check your computer of it is equipped with a software that allows viewing of PDF files. If not, you may download a PDF viewer from the link below. Once you have installed the PDF viewer, you will be able to open PDF files without any problems.
https://acrobat.adobe.com/us/en/acrobat/pdf-reader.html
Hope this helped you. Good luck!
