Any Hill
30 points
Posted on - 09/26/2012
Hello experts,
Yesterday I downloaded a Downloader for movies and it was not a high definition one, I want to download software subtitle blu-ray. My friends tell me that it has a high definition quality and I want that kind of software. Can you give me the website link that will possibly lead me to the proper way of installation.
Thank you.
I want to download software subtitle bluray.
Hello Any,
Here I have given you the whole information about the task, I think you will be able to complete the task successfully.
Use Subtitle workshop for editing tools of subtitle from here. You also can use for editing, designing and translation and creating movie subtitles by Subtitle processor.
You can download Subtitles of many Bluray movie from here.
You also can download subtitles from Subscene and from opensubtitles.
ADDING SUBTITLES TO BLU-Ray:
If subtitles are burned in the file click right > select primary subtitles, select any subtitles of your liking.
2. IF the disk doesn't have subtitles you can manually add subtitles in your own.
Follow the instruction:
Download your expected movie subtitle and then extract it.
Then find the folder of the same name of downloaded rar/zip file.
Then open the folder and then execute the program.
Then click add to add your expected movie file and subtitle files.
Then select output, select Blu-ray and click browse to store.
Click Muxing to create Blu-ray Disk.
After that you can burn software to burn the files to a disk.
Best of Luck.
