Hi Experts,
I am looking for the DWG viewer for the MAC OS X 10.6. At present, I am using edrawing but I find it unsatisfactory. I am looking for a freeware DWG viewer which can view my AutoCAD DWG Files on my Mac.
Kindly suggest me in Dwg view MAC OS x subject.
I want Dwg view Mac OS x?
Microspot DWG Viewer may be a product supported Microspot macDraft skilled that permits AutoCAD DWG files made on a laptop to be opened and viewed on Mac OS X. Throughout gap the user will select the layout which will be opened or open the Model from an inventory of accessible layouts.
The dimensions and units {can also|also will|can even|may also|may} be chosen or DWG Viewer can roll in the hay automatically. The layers within the document may be shown or hidden or colorless and also the document marked up by drawing elliptical markers in red and text may be additional with a yellow background.
It has saved in an annotation layer. The ensuing document may be saved as a PDF with the annotations and written. Zoom tools and a tool enable you to enlarge any section of the drawing and scroll around.
