I want to get help to burning CD-R.
Thank you for your question. I want try to help you. If you have installed the Nero software in your computer you can easily do it. A normal cd you should burn one time.
If you want to burn your picture or documents different times with a cd disk, you need to buy a rewritable cd disk. You can get the same facilities of pen drive from it. You can burned it different times and you can delete it any time.
But I suggest you if possible y copy and paste.
It is portable and any time and any where you can use it.
First of all you need to have writable CD drive. Check to see if there is a RW label on your CD drive
If you have any burning software such as Nero or Alcohol, insert the blank CD into the drive and open it.
Click on Create new data disk. Add the image files you need to write and click on Burn. Do not disturb the burning process, don't close the burning dialog, don't open the CD drive until the burning is complete. Note that you can write on a CD only once, after writing the CD becomes read-only.
Hello John,
You will need to have a burning software installed on your computer. Some burning software's include Nero express and ashampoo burning studio.
With the burning software installed, insert a blank CD on your computer, then open the burning software. Copy and paste the image in the blank space of the burning software and then choose the option to burn the image.
Note: You should make sure that you have a blank CD inserted in your computer, otherwise burning will not happen.
Regards
Lee Hung
