I want to get rid of found new hardware window
Hi There!
I have one amazing problem. After turning on my computer ‘found new hardware window’ is come again and displayed like confirmation after every 30 seconds of like this time.
Found New Hardware
CP2102 USB to UART Bridge Controller
But I don’t attach any hardware in my computer.
 So why this confirmation message is come rapidly after every 30 seconds?
How can I stop this notification?
Best Answer by Jordyn Clark
Answered By 0 points N/A #91732
You should try to install the Cleanup Utility, you can download it in the website of Windows.
  • Or try this method:
  • Try to remove all possible corrupted files by running Diskcleanup.
  •  Go to “Start” menu, then press “All Programs” click “Accessories” then “System Tools” and press down “Disk Cleanup”
  • Now run the SFC and Chkdsk to secure that all the corruptions are cleaned up
  •  On the “Start” menu search field, input “Command” then click “Run As Administrator”
  • And input this : sfc/scannow
  • Then analyze the files by running the checkdisk, then set it to start running after restarting your computer then, press “Ok” to finish the process
Answered By 0 points N/A #91734
You haven’t installed the driver for that device. Actually it is a bridge controller which comes with your Motherboard chipset driver. Once you have installed the driver for your Motherboard the messenger will no longer displayed or appear on your task tray.
You may double click the icon on your task tray where the balloon message originated. New hardware found dialog box show-up in your screen. Then you may check the option this time only so that next time you log-on to your computer your windows will never ask you again to install the driver. Continue the wizard until installation is finished.
