Hi, I am working as an IT assistant in my company. So I have to create some document about label parts of a CPU.
So I decided to create it using MS excel 2007. Before that I want to get some information about label parts of a CPU.
Expert please suggest me the websites to get some information about label parts of a CPU.
Thank you.Â
I want to get some information about label parts of a cpu
CPU (central processing unit ) being the brain child of the computer , It has some parts that need to be known by name and to where the connection is to be directed to the PC.
You can visit the Google select parts of a computer then click on the images task bar .
It will list many graphics and the labeling of the parts of a computer.
Here is a sample.
Hello Elyssaguadalupe,
A central processing unit (CPU), also referred to as a central processor unit, is the hardware within a computer that carries out the instructions of a computer program by performing the basic arithmetical, logical, and input/output operations of the system. The term has been used in the computer industry at least since the early 1960s. CPU is sometimes referred to as central processor. CPU is the brains of the computer where most calculations take place. It is known to be the most important element of a computer.
On personal computers and small workstations, the CPU is housed in a single chip called microprocessors. CPU, nowadays, are small and square shape with multiple metallic connectors or pins on the underside. The CPU is located in the CPU socket, pin side down, on the motherboard.
Here is the image of a CPU with its parts labeled. If you want to replace or upgrade your CPU, you must check first the motherboard specifications before doing so. Modern CPU also have attached heat and small fan on top of CPU to minimize heat. The two typical components of a CPU are the arithmetic logic unit (ALU) and control unit (CU). ALU performs arithmetic and logical operations.
CU, on the other hand, extracts instructions from memory and decodes and executes them, signals the ALU when there is a need.Â
