I want to have a program to see who is bcc
Hi masters! I am an email marketing specialist.
Having internet and email as my everyday buddy, I am quite curious when it comes to receiving email messages from clients
I want to see who is in the loop because I want to discuss some things privately.
Is there any program to see who is BCC? Where can I possibly download it?
Thanks for the help.
Best Answer by Master Blaster
Answered By 0 points N/A #135418
Hi James, your required answer is here
1. The purpose of  the BCC (Blind Carbon Copy) feature is to enable the sender to send an E-mail while keeping  his confidentiality. So that no one else can see that they received it. So there is no way to see BCC Email addresses .If there is a way to see who was on the  BCC  it would destroy  the whole purpose of  having it.
2. Sometimes you can just check (if someone is in BCC ) by the mails that  delivered to you  from known persons in your address book are going to the junk mail folder (because there has been a BCC recipient) This is the way through which you can know if your email contain a BCC recipient.
3. Some time BCC receptionists are not shown in sending mail folder , so you can review them by following the given below steps
  • Open your email account select the  “Sent" folder. Locate the email that you want to view.
  • Just right-click on the email and select "Properties." A new window will be appear.
  • Select the "Details" tab. The BCC recipients will be found in near the top of the text.
Answered By 0 points N/A #135417
Hi James,
I think you want to know about BCC. BCC is a short form of Blind Carbon Copy. The BCC is the carbon copy of the original mail that you are going to receive.
We use carbon copy to prevent the receiver to see who else have received this mail. By putting  your e-mail address in the BCC the sender does not want you to see the other recipients.
But there is a potential security flaw in the BCC feature. All address including BCC are contained in every mail when a mail is sent over the internet. BCC address is only abstracted at the destination server.
If you control your email server or manage to access the server then you can see the BCC address.
Thanks for sharing your problem with us.
Answered By 5 points N/A #135419
Hi James Mayer,
You can use this software is FileZilla. This is a much better quality software on email messages from clients.
Just download this software on this site click and go to this link.
Now install your PC and log in your user name and password.
Thanks for your good question.
