Hello Users,
I am a MSN messenger service user for a long time. But now I feel Skype gives more serviceability than MSN. So I need to remove MSN from my computer. But I don't know how. As I am not an it pro, I came here to get help from you. Please help me removing MSN messenger service.
I want help about msn messenger service
Login using administration profile.open my computer , go to control panel and right click add/remove program , click run as administrator.
You will be able to see list of programs here , choose msn services and click uninstall.A wizard will appear, follow the steps written in it to completely remove msn from your system
Regards
 Nancy D serrano
Hi there Maurice M Persaud,
Removing MSN from your computer is a really simple thing to do and since you're using your MSN account via Skype you won't lose anything by removing it.
To remove the MSN messenger click the Start button on your desktop and either via menu or search option find Programs and Features. Enter Programs and Features and locate Windows Live Essentials on the list. Once you've located it, double click on the name and click the uninstall button. A new pop up will appear where you have to check Messenger and then click continue.
Once the uninstall process is done, exit Programs and Features and restart your computer.
Best regards,
Drake Vivian
