I want to install My language font In my Symbian mobile
I have a E71 mobile which is imported from gulf. Because of that it don't have my language in it.
I can't read Facebook posts because of this. I want to clear this drawback.
Some one please help me how to install font in S60 mobiles.
Best Answer by Austin kelley
Answered By 0 points N/A #136587
Submit it to nokia centers they know what to do or:
Install opera mini
Just type on your cellphone "m.opera.com"
Another solution is:
1:Install opera mini
2:type "opera:config" on address bar
3:"use bitmap fonts for complex scripts" make the setting to " yes" and save the setting then you will goto the websites and enjoy reading.
Answered By 10 points N/A #136588
Please follow below instructions.
1. Press the Home key (Menu key).
2. Choose the icon with the wrench (Tools) in the menu screen and Click it.
3. Select the settings icon on the tool screen.
4. Settings screen, choose the first option, General. The icon will look like a wrench next to the E71.
5. General screen, select the first option, Personalization. It will looks like a painting palette.
6. Personalization screen, go down to the 5th option. (Click the Down button 5 times and then click that option)
7. Language screen will open. First option is phone language. Select it.
8. In there you can see several radio buttons where you can select the language English. Press OK .
By doing this you can view any web site in English.
