I want to install Plugins for animation shop
Hi Experts,
I have downloaded Jasc Paint Shop Pro 8, it is simply awesome specially Animation Shop is tremendous. But I want to install plug-ins for animation shop. Where can I find them?
Hi Experts,
Hi Janneya Llison
Do you have an Adobe 6.0.1?
I have learned that almost any plug-in that works for adobe will also work in PSP. You just have to direct the plug-in when you install them to your plug-ins folder in your C drive, program files, Jasc, and find where your plug-in folder is in PSP.
Here's the link for plug-ins for Paint Shop Pro:
And here's the link to download animation shop effects plug-ins.
http://animation-shop-pro-animation-plugin.sharewarecentral.com/
Regards
