I want to install Rosetta
Asked By 7060 points N/A Posted on -
May I know how can I install Rosetta for me to use PowerPC-based applications?
Best Answer by Sharath Reddy
Answered By 15 points N/A #83127
How to install “Rosetta”?
  1. At first select the Rosetta Install CD.
  2. Then you should see the "Rosetta apply cd" . Now Double click on that image.
  3. A new window will display. Now click on "Install".
  4. Select "Run Installer".
  5. Then select "Next", then "Yes", then again "Next", again "Next", again "Next".
  6. Al last select "Next", then uncheck the dialogue box and then select "Close".
Using Tutorial of Rosetta:
  1. At first Go to "My Computer". And   unmount the "Rosetta apply cd" by left clicking on the image and selecting "Un-mount". You no need the "Rosetta apply cd".
  2. Then, select a language file and mount it. When the image is mounted, Then select "Start", and then "All Programs",choose the program "The Rosetta " in program list, Then select "The Rosetta  v.2——-".
Answered By 590495 points N/A #83129
Rosetta Stone is a well-known language-instruction software that teaches users how to speak French, Spanish, Italian, Chinese, Polish, and other languages. It also has different skill levels to create lessons appropriate to your ability. Follow the instructions below on how to install Rosetta Stone.
  • You need to download Rosetta Stone from Rosetta Stone | Try Rosetta Stone for free.
  • Install Rosetta Stone after downloading it. Select the appropriate user interface language and then set the destination folder if you want to install it on a different folder or simply use the default installation folder then proceed with the installation.
  • The program will automatically open after the installation. Set the software preferences. You need to set this for the program’s first run and to be able to use the application. Click Add a Language Level to start.
  • Insert the language CD-ROM then select which language to install.
For additional information, you may visit eHow tech | How to Install Rosetta Stone.
