I want to install Skype on my phone Nokia 5250
Dear Experts,
I own a Nokia 5250. I want to install Skype on my phone. Can anyone help me find Skype new Nokia 5250. Does it work in the same way as it is used in the PC?
Dear Experts,
Hello Jane,
 It seems that your Nokia 5250 is supported by Skype !
Your phone uses Symbian 5th edition OS which is compatible with Skype. You can read more about it in here.
You can download Skype directly from them or through your mobile phone.Â
If you are planning to download through the phone, you need to open the Ovi Store app.
This app should be installed on your phone.
Another method is to visit Ovi Store through the internet and Download it to your PC and then transfer to your phone using provided USB cable.
Good luck to you.
Hi Jane, It looks like your phone is not supported by Skype. Supported phones are Sony Ericsson Satio, Sony Ericsson Vivaz, Sony Ericsson Vivaz Pro and Nokia C6, C7, E5, E51, E63, E66, E71, E72, E75, E90, N78, N79, N8, N81, N81 8GB, N82, N85, N86, N95, N95 8GB, N96, N97 mini, N97, X6, 5320, 5530, 5800, 6210 Navigator, 6220 Classic. But still you could try going the below link from the default browser on your phone to see if it can support Skype: https://www.skype.com/en/
