I want to install Unicode in my android phone
Hi guys , I want to install Unicode in my android Samsung galaxy s2 phone,is there any method to install Unicode without rooting the phone?
Erin, get the Unicode font ready in type format such as .ttf then install ADB. Open the command prompt  and type all devices. If you see some lists of devices then its ok. Now you can type the code that will start your mobile. Then make your system re-writeable using command code. If you are using ADB close all the applications in your phone and then open ADB shell while typing SU in the shell your phone may ask your  to change use,so be careful about it. I hope after this you can start installing Unicode in your android phone.
If you want to install Unicode fonts on your Android handset, the easiest way is to install FontFix. It offers more than 4,300 fonts available that you can install on your Android phone as well as install the fonts you downloaded from the internet. It supports both rooted and non-rooted devices.
Unfortunately, if you have Samsung Galaxy S7 or Samsung Galaxy Note5, you will not be able to install free fonts. All fonts included in the app are free for personal use. The app allows you to preview the font first before attempting to install it. You can also preview any font you downloaded from the internet by selecting it from the third-party file manager or directly with the app.
Samsung and other phone manufacturers support FlipFont which allows you to install fonts on your handset without requiring the device to be rooted first. All of the fonts included in the FontFix app support FlipFont. But if your device doesn’t support FlipFont, you need to root your handset before you can install a font. To try FontFix, go to FontFix on Google Play Store.
It requires Android 4.0 Ice Cream Sandwich and higher. The app offers in-app purchases.
