I want to install Webcam
I did buy a webcam for voice and video chat on my PC, but i do not know how to install a webcam , can any one
Help me regarding this?
Thanks in advance
Thanks in advance
Why you did not buy the software when you did purchase your webcam ?Â
Any way first of all check the model of your webcam, then search the software using Google or other search engine then if you find it, download and install .
And if you are not able to search it on the internet go to the shop where you purchased the web came ask them for Driver of your webcam then install it on your PC.Â
1. Solution 1 : (Installation Cd)
When you bought your webcam, you have surely received with it an installation CD which can be used to install this device drivers. Before connecting your device, install the drivers then you can connect it and it would work perfectly (if there are no error)
2. Solution 2 : (No installation CD)
If you didn't get an installation cd or you lost it, you can install your webcam by downloading drivers from the internet.Â
1. If you know your devise full name and brand, search it on Google with adding drivers on the research. When find it download the drivers and install them.
2. If you don't know the devise name, you have use a software which can recognize the device and will look for you for the drivers on the internet (for example Mydrivers). Then you have to follow the software instruction and your device will be automatically installed.
