I want to know about internet explorer second screen.
Hello experts,
I want to know if the windows internet explorer has a feature for a second screen and how will it works and be configured or shall I say setup in the control or setting bar?
Christ Hilyard.
Best Answer by Toni Linscomb
Answered By 0 points N/A #154071
There is an option in windows called multiple displays. It can use for internet explorer. to activate the multiple displays follow the steps below:
  1. Right click on desktop -> personalize.
  2. Display -> change display setting.
  3. Then change multiple display setting to “extend these displays”.
  4. Ok.
  5. Now you can use two displays for internet explorer.
You can open one IE window and move it to other display and open IE again. But new IE version has some problem. But older versions work correctly.
Change the appearance of display
Answered By 5 points N/A #154072
Internet explorer doesn’t have such an option.
But you can easily create a simple HTML form to open several web sites on the same window.
You can do this using HTML form tags.
Remember some site doesn’t allow their site to open in a fame some examples are Facebook, Google, Yahoo.
Copy and paste the below code in to a notepad. And save the notepad as MultiWindow.HTML.
Then double click and open the saved file.
