Ann Jolin
10 points
Posted on - 03/30/2013
Hi guys
Recently I know about logitech, touchpad and autocad. I am not much familiar with these tools so please suggest me whether these tools are beneficial for me? Or may I can easily used these software?
I want to know about Logitech Touchpad and autocad
Hello Ann,
It looks like you want to know about the recent Logitech touchpad and its use for AutoCAD software. The Logitech touchpad is a hardware used as a replacement of a mouse and which aids in a multi touch interface, Touch pads are very common laptops and there is also an external version for desktop and tablets. Whereas AutoCAD is mostly used for designing and architectural or engineering works. You can find some tutorial in the web on how to get familiar with AutoCAD.
I hope this helps.
