I want to know about Mac textmate merge
Hi friends,
I am here asking to the expert. I am using TextMate on my MacBook pro. I want to change its environment locally, But I don’t know the procedure. Let me clear, is it possible or not? If possible, then how I can do this ? Also want to know about mac textmate merge. A prompt response will be appreciated greatly.
Best Answer by Michael L London
Answered By 0 points N/A #179579
Hello Emaily Rawa,
If you want to change it, then there is no way because its default, but you can use different soft and you should choose on your own and I'm just going to give you a suggestion not decisions and showing you some source where you can get another. One of the most popular text editors ever is Bare Bones BBEdit and you can use it. You must see some review before using it.
Here is the link below to see http://mac360.com/2008/06/faceoff_which_is_the_best_text_editor_ever/
Thanks for asking here at techyv.com. Feel free to post your queries here at techyv.com
Best regards,
Michael L London
Answered By 50 points N/A #179580
Hello, Emaily
Hope you are fine. Please see the video result changing the environment of textmate locally on Mac book pro.
Video tutorial
You can check the manual of textmate to learn about so that how to use it.
The FileMerge utility is a great tool that comes with the Mac . But Now in TextMate, there’s no other option to compare uncommitted changes in a git repository using FileMerge.
Hope you will get your answer.
