How Delphi intercepts with the printing documents
20 points
Posted on - 08/23/2012
I am running Windows XP Professional with Delphi Pro. I want to know the connection between Delphi and my printing documents. I created a message handler for the INIT_DIALOG handler but it failed. My question is, should I use the dialog command to print or just simply print the documents?
James Yorath
