I want to know the easy steps in replacing the frontal panel
Can anyone help me how to replace the front panel?Â
What are the guidelines that are needed for the easy replacement?
Please help.Â
Please help.Â
What’s the device you are using now, is it a laptop or a desktop?
What is the software version?
This all query is must a need for your solution. However here I’m going to help you about the problem. You can replace a front panel object that you want. You can done it with a different indicator.
You haven’t to losing the label, caption, and value you set for the object.
Follow the process here I given below-
1. Place a right click on a front panel object.
2. Â Now select replace from the shortcut menu. It will display a temporary version of the controls palette.
3. In this step, you have to select a indicator the temporary control palette. It replace your current front panel object.
Hope you can now get the proper solution.
